Reading MIDI data
Reading MIDI data
Can anyone recommend a way to read MIDI data (note pitch and duration)? I would like to see actual numbers and not visual interpretations. For example, a MIDI event list. "A3 on, B4 off, etc." with time indicators.
I have many programs, FL studio, etc. But none seem to allow the user to look at actual data.
These days, is there anyway to get to anything at all without a GUI??? :shock:
a1bert
Re: Reading MIDI data
Post by a1bert »
Jeff-20 wrote:Can anyone recommend a way to read MIDI data (note pitch and duration)?
Get midicvt from http://www.vlsi.fi/en/support/software/vs10xxtools.html . The code is designed to perform midi format 1 to format 0 conversion, but you can insert your own code to show the note on and note off events. (Note that note on with velocity 0 means note off as well.)
Try MIDI-OX here:
http://www.midiox.com/
And on the same page there is a ASCII-to-MIDI converter as well. I assume this will take a saved MIDI file and convert it to ASCII (and vice versa).
Thanks! I'm going to test these out this weekend.
Schema
factor
Post by Schema »
I don't want to read the data IN and OUT. I would like to "deconstruct" a midi file to see it's numeric values. And perhaps, separate the command types so I could just see the NOTE ONs in a specific MIDI and exclude controller changes.
davidv_
Post by davidv_ »
For typical MIDI file byte mangling I just do that with my own code, but i have to admit a bare excel-like MIDI file editor would serve some purposes. What I use typically to is the event list in Cakewalk Sonar.
If MIDI files were not soo old school, maybe it would make sense for plogue (my company) to do such a MIDI editor.
