In-line Vic20 emulator in Denial Forums
Yup, I've been trying to get that to work, it's something to do with rnd(.) returning really small values (*10^-3). If I replace it with rnd(1) it works.Kweepa wrote:Anyone found working examples on the forum?
I was really hoping this would work:
http://sleepingelephant.com/ipw-web/bul ... 1&start=16
It's got a couple of {wht} type things, but that doesn't seem to be the problem...
The CPU code is really old though so it's not surprising me.
If someone found me the random number generator function I could probably track down the instruction that doesn't work.
Edit: Cool!, the bug exists in my Java code too. Makes it a whole heap easier to debug.
Ok, the problem wasn't with the cpu code, I think it was the initial state of the vias. RND(.) means to seed the random number generator from the clocks, and the T1 clock doesn't seem to be initialised on startup. So I've inited the clocks to something other than 0, and it works now.
I still have to fix the petsci conversion though as the javascript regexp replace functions get buggered when you exceed char code 127.
It should output under whichever link you click on, unless you've already clicked on a link which will probably output in whatever you first clicked on, if it outputs at all. That's just because it's work in progress though. I'm thinking of removing inline and just having it float in-front of the code until you close it.Schema wrote:Very slick!
I noticed it always puts the output in the first Code block in the thread, is this deliberate or a limitation?
I've added a new bookmark for executing prg links in-line at http://www.mdawson.net/denial/bookmark.php
It will find any links containing a file ending in .prg and change them to execute links.
Currently only unexpanded PRGs will work, I'll work on auto detecting memory requirements tomorrow.
If it isn't working check the link is still valid, is a direct link and doesn't require memory expansion.
You should be able to run these adventures, by clicking the PRG bookmark link, then typing SYS 32592
http://www.zimmers.net/anonftp/pub/cbm/ ... 20Land.prg
http://www.zimmers.net/anonftp/pub/cbm/ ... 20Cove.prg
http://www.zimmers.net/anonftp/pub/cbm/ ... ssible.prg
http://www.zimmers.net/anonftp/pub/cbm/ ... Castle.prg
http://www.zimmers.net/anonftp/pub/cbm/ ... 0Count.prg
I've changed the aspect back to 1.6ish for PRGs, and made the emulator window float with a close button and joykeys checkbox.Kweepa wrote:Wow, more and more awesome!
Would it be possible to change the aspect ratio to make the text more readable?
You'll need to update your bookmark to see the changes though.
Hopefully it's the last time your bookmarks will need updating as I've moved common code out of the link now.
I need to redo the basic link at a later date.
It's kinda fun to work through Roberts prgs, http://robert.hurst-ri.us/files/ if anyone wants to try. I think only the quikman+ one doesn't work as the + sign isn't encoded in the anchor (it means space in href land).
- Kweepa
- Occupation: Game maker
Super, thanks!matsondawson wrote: I've changed the aspect back to 1.6ish for PRGs, and made the emulator window float with a close button and joykeys checkbox.
Do the adventures work for you? They run but produce some unpredictable output, such as repeated intro messages, "TOO DARK TO SEE", and so on.
- Omega Star Commander
Cool stuff ... one funny thing with joy keys enabled, when you hold the down arrow long enough, the browser window also scrolls. Perhaps it is not eating keyboard event entirely? Regardless, it's a software marvel -- many thanks!
Heh, I thought that it was just a crap adventure game! It might be because there a few things to do to make it run, but I haven't put a restore key in so I cant test it yet.Kweepa wrote:Super, thanks!matsondawson wrote: I've changed the aspect back to 1.6ish for PRGs, and made the emulator window float with a close button and joykeys checkbox.
http://www.zimmers.net/anonftp/pub/cbm/ ... s/00README
btw: sys 64802 seems to work now.
Which browser is doing that? As I am preventing keys from bubbling, and disabling default key events.rhurst wrote:Cool stuff ... one funny thing with joy keys enabled, when you hold the down arrow long enough, the browser window also scrolls. Perhaps it is not eating keyboard event entirely? Regardless, it's a software marvel -- many thanks!
