Name: The VIC-20 Bible Series II: Pentateuch - 40 column version and graphics
Authors: Mike and Orion70
Released (final version): December 23, 2010
Requirements: VIC-20 + 24K RAM
Description: Browse the first five books of the Old Testament (King James Version) in full 40 column screen. You can select single chapters, and scroll the text with cursor up/down. Take a look at the hi-res cliparts used as "book covers", to graphic depictions of the main episodes of Graphics, and read about the very first steps of mankind in full 40-column text processing made using Mike's Minigrafik. Mike also elaborated a text compression / extraction routine to fit the whole Torah in your VIC-20 .
Download: d81 disk and batch file for easy program launch
To elevate your spirit, copy and unzip file to your VICE main directory, then double-click on pentateuch.cmd. Otherwise, expand your VIC to 24K, set the true drive emulation, the disk drive 8 as a 1581, then type LOAD"*",8,1. Wait for the program to load, then RUN and wait for the main menu to load (don't press any key at the intro screen).
Discussion here.
(mod: d/l link repaired)
