http://www.mdawson.net/vic20beta/vic20.php
Opera is ok too, but not brilliant.
Firefox users beware your machine will get bogged down! (Seriously you'll be waiting a long time before you see anything).
If you've got Internet Explorer don't even bother.
Those of you with Google Chrome or Safari will like this...
I just took a couple of days of from my Java version of the emulator.
Completely based on my own work.
To be honest I just changed it last night with some pretty graphics, more carts, a bit of compression, and some work arounds for Opera issues.
So you're probably the only one who's seen the better one.
It just occured to me that those of you using firefox will probably not see anything unless you update the following setting.
Go to Firefox and type "about:config" in the address bar, then find the option "javascript.options.jit.chrome" and set it to true.
It'll still be unusable but at least you should see something.
Where is the "C64 javascript emulator" ?Kweepa wrote:Wow, that's awesome!
Nice job. Is it based on a C64 javascript emulator or written from scratch?
I don't suppose javascript allows you to output generated sound...
I've had a look round on the net, but all i can find are fakers.
i.e. things that don't emulate or run anything but make a screen that looks like a c64 that says syntax error for anything you type.
- Kweepa
- Occupation: Game maker
I don't know if there is one. And if not, all the better!matsondawson wrote: Where is the "C64 javascript emulator" ?
Since you're writing a Java emulator, have you seen JarVIC?
http://www.kweepa.com/step/vic20/jarvic.html
