I do not have the Vice emulator as i wish to use the REAL VIC-20
I see many members have wrote and uploaded there own Games
How would i open the prg file to see the scrips to type this in to my VIC-20 then save this to Tape..
What software would let you open the prg file?
Many thanks..
Please be gentle i am a Newbie
Reading Code in prg file?
Uhm... VICE? You'd stop the program and then enter LIST to show the program.What software would let you open the prg file?
There are some *.prg to ASCII converters around. However, printing out the program, and then re-typing it into the VIC-20 is a quite cumbersome, and error-prone process. And more or less restricted to pure BASIC programs.
In most cases, *.prg (or for that matter, *.d64) files either are copied to a disc using the 1541 connected to the PC via a X1541 cable. Or with SD2IEC or uIEC/SD, which take SD cards written on the PC, and are attached via the serial cable to the VIC-20 and act as floppy drive.
Thanks orion70!
A very nice idea, link.
I just came across this on YOUTUBE.
http://www.youtube.com/watch?v=ecxADZwybfE
Some guy is saying you can use some pc software called
"audio Tap"
Running a cable from the pc's Audio out to a tape recorder
and record the converted .Tap file.
On the Youtube video scroll to time 8.09
It explains There.
What you think of this?
"audio Tap"
It explains There.
