Basic Raster
Legacy
Basic Raster
Post by Legacy »
Who says you cant write raster routine in Basic ?
Works with VICE 2.1 PAL unexpanded :D
10 a=240:y=4:x=6
20 poke36865,a
25 fort=1to200
30 poke36879,y
40 poke36879,a
50 poke36879,x
60 poke36879,y
70 poke36879,a
80 poke36879,x
81 nextt
100 poke36879,27:poke36865,38
run
works also if you omit lines 60,70,80
Ok so it's not a real raster routine, but it looks like one!
The only way to program better is to find a better programmer. - Legacy 2009
Leeeeee
soldering master
Post by Leeeeee »
This makes it a proper raster routine..
10 A=240:Y=4:X=6
15 P=36879
16 W=36868
17 V=128
18 U=32
20 POKE36865,A
25 FORT=1TO200
27 WAITW,V
28 WAITW,U
30 POKEP,Y
40 POKEP,A
50 POKEP,X
60 POKEP,Y
70 POKEP,A
80 POKEP,X
90 NEXT
100 POKEP,27
110 POKE36865,38
Lee
DELETED
Post by DELETED »
DELETED
amramsey
Post by amramsey »
MRaider wrote:Sadly upper-case, and I can't be bothered to type it in manually. :D
10 a=240:y=4:x=6
15 p=36879
16 w=36868
17 v=128
18 u=32
20 poke36865,a
25 fort=1to200
27 waitw,v
28 waitw,u
30 pokep,y
40 pokep,a
50 pokep,x
60 pokep,y
70 pokep,a
80 pokep,x
90 next
100 pokep,27
110 poke36865,38
And also for Vice:
http://www.aaronramsey.com/commodore/misc/RASTRPRG.P00
:D
Legacy
Post by Legacy »
How do I load a .P00 file into Vice?
amramsey
Post by amramsey »
Well, I'm no VICE expert... what I did was have device 8 pointed to a directory on my PC (in the peripheral settings for drive 8). When I do something like a load"$",8, it shows the programs that I have on my PC in that directory. I pasted that program in and saved it 'save "raster.prg",8' and it stuck that RASTRPRG.P00 on my hard drive.
So you can either point drive 8 at a directory on your PC and use it that way, or you can can use 'Smart Attach Disk/Tape" and just point it at that file. It will automatigally load the .prg and wait for you to type run.
I have no idea why it made a .P00 file instead of a .prg file on my drive.
tlr
Post by tlr »
In Vice:
1. Go to Settings/Peripheral Settings/Drive 8(tab)
2. Untick the Write P00 files box.
tlr
Post by tlr »
Legacy wrote:How do I load a .P00 file into Vice?
Open it using File/Autostart disk/tape image...
Legacy
Post by Legacy »
That's not workin TLR
amramsey
Post by amramsey »
Thanks tlr.... P00 files are disabled on my machine now.
Legacy, try this .d64 image instead: http://www.aaronramsey.com/commodore/misc/raster.d64. Not sure why the autostart isn't working for you. Are you using the latest version of VICE?
Legacy
Post by Legacy »
no go on that one
**** cbm basic v2 ****
3583 bytes free
ready.
load"raster.prg",8,1:
searching for raster.p
rg
loading
ready.
run
ready.
amramsey
Post by amramsey »
Legacy wrote:no go on that one
Ah... maybe I see the problem. I've got my VICE vic-20 set to max memory. I wonder if the ,8,1 is screwing up the basic load?
Try loading it with just load"raster",8 and see if that works.
Legacy
Post by Legacy »
LOAD"RASTER",8
That worked, I don't know much about the 8,1 options I know 8 is device disk drive like a 1541 5 1/4" floppy drive, not sure about the 1 parameter, I just assumed it was always supposed to be there.
I really should invest in a uIEC drive and run everything from the real deal but Im not working now so money is tight. Luckily I got IBM thinkcenter on newegg for $100 complete system!
Thanks for the help I was starting to wonder if my vice had a bad processor :D
nippur72
de Lagash
Post by nippur72 »
exactly what's the reason for:
27 WAITW,V
isn't enough the WAIT in line 28?
The first WAIT synchronizes the raster line, the second waits for a particular line to make the effect happen.
NTSC = 261 lines, PAL = 312 lines.
Unless I'm totally confused, it means $9004 will become 0..4 twice per frame in NTSC, 0..55 in PAL. Waiting for raster line 128 then 32 means in NTSC the effect will end up on line 32, on PAL on line 288. Somebody please correct me if I'm getting this wrong.
