My 1541U
First off, the 1541U plugs into your 64's expansion port not the user port but I suspect you got the names mixed up as the genders are different and the 1541U wouldn't fit in the user port. Anyway, plug it in the expansion port and then run a serial (IEC) cable from the VIC-20 to the 1541U. Turn on your 64 and then turn on your VIC-20. Use the 1541U's on-screen menus to select the d64 with your VIC-20 software. When you get to the 64's BASIC screen, switch over to your VIC-20. Type load"$",8 and the 1541U will respond. You have just turned the 64 + 1514U into a disk drive for your VIC-20.
Honestly, it seems like a waste to use a 1514 Ultimate exclusively as a disk drive for the VIC-20. Full 1541 emulation (for lack of a better word) is only of value when using software that reprograms the drive and I don't think very much (if any) VIC-20 software does that. You'd probably better off with a device like the uIEC which is a lot less expensive.
- Schema
- factor
Some of the recent demos (Robotic Liberation, etc). do program the 1541 in order get the "streaming" speeds. I've tried them on my uIEC and they don't work, as expected.gklinger wrote:Full 1541 emulation (for lack of a better word) is only of value when using software that reprograms the drive and I don't think very much (if any) VIC-20 software does that. You'd probably better off with a device like the uIEC which is a lot less expensive.
For 99% of VIC uses though, the uIEC is perfect!
That's interesting. We have got to give Robotic Liberation a go. I never bothered as I only have NTSC VICs but if you've got a PAL one...Schema wrote:Some of the recent demos (Robotic Liberation, etc). do program the 1541 in order get the "streaming" speeds.
I wasn't able to run Robotic Liberation and many other demos on my VIC.. I'm such a newbie. I managed to run Impossiblator 2 but Impossiblator 3 didn't work.. the loader routine got stuck. I understand what the problem is but cannot fix it.
And how about the next level? It's a single d64 file, how can I manage it? I have seldom used disk drives so excuse me and my dumb questions
Just for those who might not know in relation to using the VIC-20 with the 1541U, here is a great little app for navigating the contents
http://www.1541ultimate.net/content/ind ... 44&catid=9
another happy owner of a 1541U
I mentioned that here. It's definitely worth checking out.jokker wrote:Just for those who might not know in relation to using the VIC-20 with the 1541U, here is a great little app for navigating the contents
Hi. Yup, that's me, the author. (Or should I say: "I wrote that!" )gklinger wrote:I mentioned that here. It's definitely worth checking out.jokker wrote:Just for those who might not know in relation to using the VIC-20 with the 1541U, here is a great little app for navigating the contents
The app is feature complete, but still contains one bug: the BASIC relinker call after a file has been loaded mangles the loaded BASIC program. Haven 't had time to look into that; but a manual reload will fix this at the moment.
Maybe somebody here will look at the offending load&run code, and easily spot what I am doing wrong:
ERROR = $C437 ; BASIC error routine
RUN = $C871 ; basic 'RUN'
CLR = $C659 ; basic 'CLR'
RUN_NEXT = $C7AE ; basic WARM start
ldx $2b ; load address
ldy $2c ; load address
lda #0 ; load, not verify
jsr $FFD5 ; LOAD
bcs error
pla
pla
jsr CLR
jmp RUN
error tax ; load error code
jmp ERROR ; print error
Do you mean the Basic program won't start properly after loading? Perhaps some of the pointers are not set accordingly after from the Kernel LOAD routine. It has been discussed before in various threads and in addition to $C659 and $C7AE some more call(s) may be in order. Search the forum for those addresses and you'll find some old threads.
Some of the recent demos (Robotic Liberation, etc). do program the 1541 in order get the "streaming" speeds. I've tried them on my uIEC and they don't work, as expected.Schema wrote:gklinger wrote:Full 1541 emulation (for lack of a better word) is only of value when using software that reprograms the drive and I don't think very much (if any) VIC-20 software does that. You'd probably better off with a device like the uIEC which is a lot less expensive.
How about the prg at
http://www.pouet.net/prod.php?which=10626
It's a 16k version that is emulator friendly, but does that work on the real thing using uIEC?
