.d64 -> .tap
aneurysm
not your PAL
.d64 -> .tap
Post by aneurysm »
i spent some time lookig for a solution
.prg -> .tap seems to be no problem
but i can't find a utility that will get individual programs out of a disk image
vic user
VicGyver
Post by vic user »
i have a program on my work computer that can convert the files found in a .d64 to individual .prg files. It's called 1541.exe or something.
Schema gave me the link a while ago.
When i get to work, i will either give you the link or send you the zipped file.
chris
ChristopherT
Re: .d64 -> .tap
Post by ChristopherT »
aneurysm wrote:i spent some time lookig for a solution
I use D64Editor by Forest Mook for working with D64 images. It will
create them, let you import and export files and has a sector editor
too. I use 64Copy by Peter Schepers to create .D81 and .D71 images,
then I format the images with WinVice.
Christopher
Proud owner of VIC-20 Serial #P1069347, still in
it's original box.
I believe Marko Mäkelä's cbmconvert will also extract PRG out of a D64 (and so does X1541 which comes with VICE). I'm not sure if there is a program that both supports D64 and TAP though; you may have to do it in two steps (for religious reasons).
vic user
VicGyver
Post by vic user »
here is a link to that app. i was talking about:
http://web.ncf.ca/ex809/W1541.zip
chris
vic user
VicGyver
Post by vic user »
http://web.ncf.ca/ex809/W1541.ZIP
sorry, try this one, forgot about the uppercase
aneurysm
not your PAL
Post by aneurysm »
i like the D64Editor...
thanx guys
