Hi all,
I always said (since about 1998) that when a Linux distribution would work 'out of the box' for me, I'd bite the bullet and attempt to learn Linux..
So, finally, and to my surprise, I discovered that Ubuntu 8.04 works, out of the box, with my 6month old laptop - that is, sound, graphics, wireless drivers etc all working well without having to mess around with drivers that don't work or don't exist. I'm impressed so far with the speed and efficiency compared with Vista, though I've got that horrible yet familiar feeling of not knowing what the hell I'm doing or talking about.
So I'm (once again) a newb. I have managed to get VICE working, thanks to an excellent 'how-to' on the following link that shows how to configure it, make it and install it. Seeing the Vic fire up under GNOME is a sight for sore eyes.. For those playing at home, the link is as follows:
http://ubuntuforums.org/showthread.php?t=278022
However, to get DASM working, I have absolutely no idea. There's no configure file, when I try to 'make' it from the src directory I get
Makefile:24: *** missing separator. Stop.
and that's about it.. I know I have to compile it, it appears to be written in C, but that's ALL I know. Seriously, that's it!
I would be most grateful if someone can guide me as to what I'm supposed to be doing to get this to work.. I don't wanna go back to Vista just to create Vic20 programs!
-Glen
Installing DASM on Linux
3^4 is 81.0000001
- Vic 20 Devotee
The answer is you don't compile it. There already is a binary in the bin directory of the DASM package. If there is not then make sure you got the latest version of DASM from http://dasm-dillon.sourceforge.net/. Once you can see that the executable dasm runs you might want to place it somewhere in your path by doing
That is where I have it. doing that means that it will run from the command line but you can't upgrade it without manually overwriting it. Not that that really matters. If you have any more problems ask here I use DASM under Ubuntu 8.04
sudo cp dasm /usr/local/bin
Thanks Richard!
yay! It works
interestingly, the latest downloads (from the project page) don't include linux binaries, but I found the previous version elsewhere so that was good advice.
After copying the file into the common 'path' directory, the ownership of the file changed to 'root', meaning I was getting 'permission denied' every time I tried to execute the file.
I changed it via sudo chmod a+x dasm, so in the process learned something about how permissions work on linux..
alround pleased as punch..
hasta la vista, Vista..
-G
yay! It works
-G
3^4 is 81.0000001
As for reference, I just downloaded DASM 2.20.11 and had no difficulties to compile it on Debian something or other, kernel version 2.4.27. I did get a handful of warnings though, but I don't think you can avoid those without rewriting the code.
Since Ubuntu is based on Debian, it sounds strange if it doesn't compile at all on your computer. Perhaps Ubuntu doesn't come with GNU Make, or rather you have some old, bizarre Make prior in your path?
- Vic 20 Devotee
I believe that you need a package called "build-essential". That will enable you to compile software.
I just checked that 2.20.11 compiles on my box. It does come up with many warning errors and make install does not work. Maybe you have not got all the right packages? Or as you say it was an older version of DASM?
sudo apt-get install build-essential
