Problem with Lode Runner cart
- Mayhem
- High Bidder
Anyone else got a real Lode Runner cart for Vic20? Just got a copy of it, plug it in, title screen comes up. Can access the level editor, but when I try to start the game, the screen wraps in and then the computer crashes to a Ready prompt. Want to know if this is a problem with the cart, or the fact I'm running it on a PAL machine. Cheers!
- Schema
- factor
- Mayhem
- High Bidder
Well I was randomly pressing some buttons and got to the level editor, so it is in there. You can also save them out as I also randomly found it asking me for tape, disk or abort following some other button press(conclusion being you can load them in).
Sounds like I might have a borked cart then sadly if Mika can run his in PAL land![Sad :(](./images/smilies/icon_sad.gif)
Try to clean the cartridge's connectors with cleaning alcohol.
/Anders
/Anders
- Mayhem
- High Bidder
