Basic Program CONTEST (project 1)
Ok I have something, but everytime I get going I realize I would prefer to make it a longer program! I have the basic play, but I want to add levels and introduction screens!
Ok... I need help. I have 2 programs as wave files. I would like to make them available here as TAP, MP3 and type-in files. Can anyone talk me through the process? or even do it for me from the wav file?
MP3? Ok, the frequency span isn't that large, but to me it sounds a little risky to compress audio representing a data stream without control how it is compressed.
From WAV, you should be able to use tape64 (!) to create a TAP file. However, I remember it doesn't work very well with VIC-20 WAVs, so I have a patch somewhere. Either you get the source code and install it yourself, I publish a ready made PC executable or I can try converting the file for you.
Once you have a TAP file, life is much easier. Now you can use various converting programs including feeding it into the emulator and from there save it as a PRG file on a (virtual) disk. This program file can now be fed into tok64 (!) or bastok and generate a text listing you can cut'n'paste.
Of course, if you are natively developing on the VIC, owns a disk drive and a X*1541 cable, you can save your program to disk and get the PRG directly from the disk to the PC with the cable.
i own an x1541 cable, but I thought it wouldn't work on newer (post-486) computers...
I'll try it out. But I may just ask you to do it for me. :wink:
X1541 might not (but its worth a try - parallel port in SPP/standard mode) but if that cable was XE1541 it should be more compatible. This yet again reminds me that I'm supposed to make myself a cable. Grmbl. I need a good soldering equipment first.
drats!
I need the software too. I use to use Star Commander on my old 386sx laptop...
I don't know where to start!
vic user
VicGyver
Post by vic user »
You can dowload HDD64 or whatever, for free, and that will work with the cable.
Here is a link to the guy's site:
http://www.64hdd.com/index_en.html
I have the software but no cable, the opposite of you ')
Chris
Star Commander should work even in Windows XP after tweaking and installing dosemu. I haven't tried it myself, but if Joe states it on the official web page, it should have some kind of truth to it.
http://sta.c64/org/sc.html
I FINISHED!
I just got an idea today and in almost one sitting finished a game. I now have to type it in to the PC. It is only twenty lines and I don't feel like figuring out the cables to transfer it.
I will post it soon. I am thinking about starting a new topic category: Programs. A sections where one can just leave type-in programs for comment. Think I should?
aneurysm
not your PAL
Post by aneurysm »
don't see why not
