Someone has these cart images ?
- Mayhem
- High Bidder
Here there is the Commodore 8K Expansion switchs table:Mayhem wrote:Oh okay, I do have that as well. I was trying to use my switchable one and it wasn't liking it, nothing happened when I typed the SYS command.
| Commodore 8K Expansion |
|(Remove the case, Switchs inside)|
| Block Switch |
| 1 4 |
| 2 3 |
| 3 2 |
| 5 1 |
- Mayhem
- High Bidder
- Mayhem
- High Bidder
- Pinballer
This cartridge does not allow to set 8k in block 5.Mayhem wrote:I got a Vixen switchable between 3K, 8K and 16K and it was just reverting back to the boot screen when typing the SYS. I assume it wasn't hosting the 8K on block 5... I'll get something together for sending along.
| Vixen 16k switchable |
| Block/s Switch/s |
| 1 +3K 1B/2B |
| 1/2 1A/2B |
| 2/3 1A/2A |
| 3 +3K 1B/2A |
- Mayhem
- High Bidder
Well I opened up my standard 8k and changed the switch over. Funny how my Vic then wouldn't boot up unless I had the disk drive off first. Can't explain that one. Anyhow, here's the results of trying to load the dumps...
Mobile Attack - nothing, didn't boot (real cart worked fine iirc)
Frogman - booted, didn't crash immediately, fell over when I started a game (though the real cart was fine iirc)
Key Quest - no issues once again
Anyhow, you can now find the three dumps and the scan of Key Quest sheet here...!
http://www.mayhem64.co.uk/misc/newdumps.zip
If someone can get them working fine in Vice, that would be great too. I hope the dumps all work on a real Vic properly too... cos they all boot in Vice at least.
Thanks for your persistenceMayhem wrote:Anyhow, you can now find the three dumps and the scan of Key Quest sheet here...!
I will test them on real hardware tonight (stand alone mode) and then on Mega-Cart.
All these carts works in vice too, you need to load Mobile Attack and Frogman as ROM, these carts don't work in ram.Mayhem wrote: Mobile Attack - nothing, didn't boot (real cart worked fine iirc)
From Vice:
File ==> Attach Cartridge Image ==> 4/8k image at $A000
Or you may use this command:
xvic.exe -cartA cartname.prg
Mobile Attack freeze in vice after a while, it's a Vice bug, just ALT+R to do a soft reset and Mobile Attack doesn't freeze anymore.
Frogman it's a Dot Gobbler clone or Dot Gobbler it's a Frogman clone in any case it's NTSC but i may fix it for PAL too.
Key Quest is NTSC too, i need to check if is PAL fixable.
- Mayhem
- High Bidder
Oh I was attaching them as carts at $A0 in Vice, just that for Frogman it crashed immediately on booting for me (in NTSC or PAL). And as you say Mobile Attack randomly freezes. Just wondering if these can be fixed without having to resort to hitting Alt R etc.
You saying that Frogman did NOT crash immediately for you in Vice? What version are you using?
And yes, it's Dot Gobbler with different graphics. Why OEM figured they could sell the same game twice...!
Vice 1.21 for windows, i've retested Frogman and it and works great, it must work in ROM not in RAM, in ram crash after a while.Mayhem wrote:Oh I was attaching them as carts at $A0 in Vice, just that for Frogman it crashed immediately on booting for me (in NTSC or PAL). And as you say Mobile Attack randomly freezes. Just wondering if these can be fixed without having to resort to hitting Alt R etc.
Obviously since it not work in ram doesn't work in real vic too if you use ram in BLK5 that you cannot write protect but works if you reburn the eprom.
I've no solution for Mobile Attack, it's a vice problem.
- Mayhem
- High Bidder
Well this is interesting... I'm using 1.21 as well, and I just tried booting Frogman again in ROM and it works fine in NTSC for me. Still crashes on boot in PAL though. Agree on Mobile Attack.
Can anyone fix Mobile Attack to stop it crashing, or are we just going to have to grin and bear it until Vice is updated properly?
Oh and does this mean I get a last minute credit on the multicart?
We should be able to squeeze you into credits for Mega-CartMayhem wrote:Oh and does this mean I get a last minute credit on the multicart?
Do you wish real name or Denial forum handle?
