Jeff-20 wrote:What about those "Universal Power Supply"s from Radio Shack? They read:
Power Voltage DC 3, 4.5, 6, 7.5, 9, 12 V (1000 mA)
The focus on Voltage made me think that it was the most important thing. If I find an off brand replacement, I'm likely to have some difference...
...and "1000mA"? Does 1000 Milliamperes out meet my needs? Are these things frying equipment?
Look at it this way: Most homes have 100 amps of service. Each circuit in a home usually has a 15 amp breaker; that means that each circuit can provide up to 15 amps of power. Most devices that are plugged in only use a small fraction of that. Thus, the rated amperage of the universal power supply is the maximum that it has been tested at delivering. If your Sega CDX only draws .8 amps, then either power supply would work. However, if it draws 1 amp, the replacement power supply may not be able to provide sufficient current. Note that this would be peak amperage; that is, the maximum amount of power it would require. It is quite possible that, at boot-up, the CDX isn't pulling all the power it requires when it's operating at maximum power.
As for voltage, we all know that household current in North America is 120 volts; however, in actual fact, this fluctuates, sometimes as low as 110 volts, sometimes as high as 130 volts, with no ill effect to devices that are connected since they are usually supplied with more than enough current. Thus, as long as sufficient current is being supplied (amperage), small fluctuations in voltages shouldn't hurt (especially .5 volts).
