perl recomment program.prg file.asm
but it replies:
You don't exist. Go away!
looking the recomment script it seems that try to compile (COMPILER = gcc -E) but exit because don't know the user name
Script part:
# Options
$COMPILER = "gcc -E"; ### Default C Compiler Preprocessor
$USER = $ENV{USER} || die "You don't exist. Go away!\n";
$HOST = `uname -n` || die "No host. Where are you?\n";
