HELP!
HELP!
My web service has a file count limit. I am almost at that limit. I searched my files with a file manager and found 37,000 files connected to this forum labeled "wordmatch" and 8,000 labeled "wordlist".... are these safe to erase???
I don't want to damage the forum... I have about 1,400 files labeled "posts" and 200 labeled "topics". If I keep these, the forum should be ok, right? The wordmatch files may be just for searching the forum... if I erase it, what would the possible effects be?
Sheesh.. I have no idea how a phpBB installation looks like from the inside. I thought it was all handled in a database, but maybe you have the option to choose between a db and files on the hard drive if you don't have a db to use.
Maybe there is a support forum at the phpBB site where you can get advice. If possible, you could store the 45,000 files locally, remove them from the site and see if it affects how it works. If something breaks, you can try to put them back, or at least a selected part of them.
![Image](http://www.cbm.sfks.se/i/compact.gif)
![Image](http://www.cbm.sfks.se/i/vic20.gif)
![Image](http://www.cbm.sfks.se/i/c64.gif)
![Image](http://www.cbm.sfks.se/i/electron.gif)
![Image](http://www.cbm.sfks.se/i/bbc-b.gif)
There are in a database. I wasn't being clear... I have the option to delete this files from the database, but they do count in my overall file count....
I am not sure if I have the ability to save and restore these files locally... I guess I will have to risk it because the forum would be frozen if I don't. I suspect (considering the name) that it may disable the search function. I was hoping for some confirmation... I will do as you suggest and look for other experts. IN the meanwhile, does anyone here work with forums?
ok. I restored to a previous backup state. Apparently, I could read all the new posts but other visitors could not (!)
I am still in great danger of having the site shut down in a few days because of the file count. I have to figure this out quickly.
THe table in the forum database labeled "phpbb_search_wordmatch" contains 37,000 records which I believe to be saved as individual files. My only temp solution is to prune the forum (a process that discards older posts and less frequented topics). I really would like to avoid doing that as it is only a temporary solution.
Someone please confirm that they can read this and post successfully. Thanks.
yep, i have read your posting.
maybe Erik from the vintage computer forum can help you.
he uses the same forum thing you do.
here is is site, and i am sure you can find hi addie there;
http://www.vintage-computer.com/vcforum/
i am sure he would help you if he is able to!
chris
chris
Wouldn't it be possible to turn all search things off so that no new search words are added to the database?
/Anders
/Anders
Still it sounds strange that a record counts as a file. Maybe it depends on which database software you use - is that MySQL, Postgres or maybe SQLite (which is a PHP invention that doesn't require a database server)? I'm wondering if the last one doesn't emulate database by storing files on the disk.
If I can remember, I can download and install a forum tomorrow evening (European time) to see how it configures and if I spot something odd. A little depending on what you want to do and how long contract you have with your current ISP, you might look for another provider if the problem is the services (type of database) they offer does not match your needs.
I am just trying a trial-and-error process. I am trying something new everyday and waiting to see if others can post. Someone please post here after I have tried something new and posted.
THe next experiment is to empty the tables without dropping them. The PhpBB forum suggested this, but they are stumped as well...
It seems to work fine now! Good job Jeff!
/Anders
/Anders
