How Do Tape Accelerators Work?
I remember seeing plenty of ads for carts and programs to accelerate the tape drive for the Vic. How do they work? I don't get it.
I'd say that they work something like the Turbo Tape programs for the C64...
I'm not an techie-expert on this but...
They all play around with the signal to the taperecorder. Using "shorter" signals for 1 and 0 than the original. Then they alter some of code in reading from tape and process the signals to handle this.
Well, someone else must have a better explanation, but this I think is the concept behind it.
// Zee
// Zee
Check out my humble collection of old 'puters an such
http://www.zeela.se
http://www.zeela.se
- Schema
- factor
I believe Turbo Tape 64 was invented in 1983, and other turbo loaders (Jeff Minter/Llamasoft used one, Ian Gray/Interceptor Micros used another) were of the same date. The VIC still was around in 1983, but maybe starting to fade a little. Also, even expanded VIC games load within 16K or less, so the loading times of half an hour were not as important to cure as on a bigger machine.
![Image](http://www.cbm.sfks.se/i/compact.gif)
![Image](http://www.cbm.sfks.se/i/vic20.gif)
![Image](http://www.cbm.sfks.se/i/c64.gif)
![Image](http://www.cbm.sfks.se/i/electron.gif)
![Image](http://www.cbm.sfks.se/i/bbc-b.gif)
Half an hour? Doesn't 16k load in about 5-6 minutes without turbo? Or maybe that was your point?
/Anders
/Anders
- Mayhem
- High Bidder
