Cardco Cardboard /3s
doug_in_nc
Occupation: Engineer
Post by doug_in_nc »
Does anyone either have a Cardco Cardboard/3S 3 slot cartridge sport expander manual they could scan and upload here, or better still know where I could find a scan of one? My googling skills have failed me.
I was able to find the dip switch settings, but not a copy of the manual
Dip 1: Slot 1, block 5
Dip 2: Slot 1, block 3
Dip 3: Slot 2, block 5
Dip 4: Slot 2, block 3
Dip 5: Slot 3, block 5
Dip 6: Slot 3, block 3
Dip 7: Blocks 1 & 2 for all 3 slots
Snogpitch
Re: Cardco Cardboard /3s
Post by Snogpitch »
My heart sank when I opened the box and manual wasn’t there. Fortunately I found it in my manual drawer. I will scan it in the next week and post it here if you are still looking for it. FYI the 6 manual is very similar and has most of the same material. https://commodore.bombjack.org/vic-20/h ... _6_VIC.pdf
doug_in_nc
That would be great. I have the 6 manual, and it's available online, but I haven't been able to find the 3manual.
Same here :D
Snogpitch
Post by Snogpitch »
Could not post the pdf here, so it is available at https://www.mediafire.com/file/qoskqtn8 ... 3.pdf/file
You should send this to David so it is preserved on the Bombjack archive
Snogpitch
Post by Snogpitch »
If you have compared the two, they are mostly the same with the exception of the differences between the 6 and the 3 switches and it's cabling.
mathom
Occupation: Software Engineer
Post by mathom »
And going on a year later, I have to thank @Snogpitch for the scan. I just got my hands on one of these.
...mathom...
