Sid-20 mod for the Vic
I've had these prototype boards that fit the vic sitting around, and
was wondering what to do with them, so I added a 6581 sid
chip to the vic-20.
I had to use an external 12v power supply to feed the sid, and I added
a regulator to keep it safe (not many 6581s around anymore!).
Maybe if I found a 9v sid, I could steal power from the user
port?
I finished putting it together tonight, and converted some of
my old (20 years!) basic sid programs to work. The sid sits
at $9800 (38912) so just change the s=54272 line to s=38912 and
my programs worked right away.
Its not very pretty yet:
http://home.alltel.net/bf63349/sid20.jpg
but it was built using parts I had (except for some capacitors I
bought at Radio Shack).
I would like to add a second sid to my 128d. Can any of you musicians
out there point me to some programs that use them?
Brian
chip to the vic-20.
port?
Brian
Re: Sid-20 mod for the Vic
What about building the voltage doubler the C64 uses to generate 12V?yoyodyne wrote:I had to use an external 12v power supply to feed the sid, ....
___
/ __|__
\ \__|_\
\___| URL: www.baltissen.org
Yoyodyne, this game is supposed to support a SID chip at $9140:
http://www.cbm.sfks.se/files/battleships.bin
http://www.cbm.sfks.se/files/battleships.doc
I suppose an internal mod is required to address some extra hardware in I/O block 1, since the cartridge port only has lines to blocks 2 and 3?
I thought about a voltage doubler, but the external
power supply was easiest last night.
Thanks for the link to the circuit!
Brian
Brian
Any chance of you putting a diagram of the curcuit on here for us to see?
Does it use an external speaker? What about using other sound chips?
Also, I have a Z80A CPU laying around. Could that be used by the Vic as maybe a co-processor or something. This stuff is a little out of my league, but I'm studying some electronics.(The talk about the reset switch and the debounce curcuit in another part of the forum got me intrested.)
Just curious,
Just curious,
Rob
- saundby
- Website: http://saundby.com/
Z-80
Yup, with the lines the Vic brings out it would be perfectly possible to add a Z-80. You could do it something like the CP/M cart for the C-64, but a bit more intelligently. See Ruud's site for info on that cart:
http://www.baltissen.org/index.html
-Mark G.
-Mark G.
If you want something like a cart, you can forget it. The 6502 outputs its address line directly at the expansion port, just like the 6510 in the C64. But, unlike the 6510, the 6502 cannot be tri-stated. End of the story.GreyGhost wrote:Also, I have a Z80A CPU laying around. Could that be used by the Vic as maybe a co-processor or something.
I could dream up a schematic that enables you to have a Z80 parallel to your 6502 but, with no software available, will it be worth the trouble?
Feel free to email me.
___
/ __|__
\ \__|_\
Sure! Just give me some time to make something readable!GreyGhost wrote:Any chance of you putting a diagram of the curcuit on here for us to see?
It was really simple, I can give a pin by pin description.
I added a small circuit for the audio, but it duplicates what theGreyGhost wrote: Does it use an external speaker?
64 uses between the sid and the audio output. I have an
old amplified pc-speaker that I used for the sound. I imagine you
could use other sound chips besides the sid, but I haven't any to
mess with.
- Pinballer
You should of been at World of Commodore as Prophet54.com was there demoing their program to run off the SID...droolral-clan wrote:Hi Yoyodyne and all.
Did plans for this SID add-on ever get made up? I've got the SID bug and a few extra experimenter boards (no SID chip yet though). I'd really be interested in building one of these SID-20 boards!
Brian
Yeah, I've been following the Prophet 64 project since before its release. VERY GOOD software. I'm so tempted, but I don't want to get into the whole other world of C64 collecting. I don't even have a C64, and have no room to set one up. Maybe if someone gives me one for free out of the blue one day I might buy this cartridge. But, as I said, VERY tempting.
That's sort of why I'd just like a SID cart for the VIC.
