Has anybody got Over5 working on macOS? The linux version seems to compile okay but I can't get it to do anything. It is entirely possible that I'm using incorrect syntax. I have verified that my serial connection between the VIC and the Mac is operational. I can type back and forth with a terminal program on each end. The contents of .over5rc is:
DEVICE=8 ;cbm device number
SERIALDEVICE=/dev/tty.usbserial-1444110
tty.usbserial-1444110 is the device for the prolific usb serial connector I'm using.
Using the command line:
results in a "Bad address" error. I haven't been able to find out what this error message means.
I have also tried to use the linux version of Over5 in a Debian build running in a VM. Same deal here. I can communicate with the VIC terminal to terminal. The contents of .over5rc here is
SERIALDEVICE=/dev/ttyUSB0
Using the same command line here nets me an "Input/output error." No idea what this means either.
Any tips, hints, or suggestions greatly appreciated.
...mathom...
