New Release : BLUE STAR
- Kweepa
- Occupation: Game maker
Thanks!
I made <fire> jump and <up> fire because you do a lot more jumping than firing, and precision jumping is tricky with <up>.
I don't have any specific POKES, but the source code is here:
http://www.kweepa.com/step/games/BlueStar8Apr2008.zip
Unfortunately it needs to be pucrunched to work - so depending on how you do POKES, it could be tricky.
Re: New Release : BLUE STAR
So I just had a go with this game and about an hour later I managed to crack it, but boy are my fingers aching.
Just one thing (highlight below to see spoiler)
Is there supposed to be No Ending, you just shoot the cpu and it disappears then you are stuck in the room?
- Kweepa
Hmm, I thought it reset to the title screen, but I could be wrong.
It's been a while.
It's been a while.
Well I was playing it in vice rather than a real Vic, with the keyboard.
Maybe I destroyed the CPU blocks in the wrong order.
- Kweepa
Hilarious!
I like your vision of the enemies
Saw the 9.99 range on the Future is 8-bit
So since I had all the parts I remixed it into a cartridge cover
If you think about releasing it on cartridge, though the game may be a bit small for that I guess.
Unless an intro, a boss battle and ending are added
Back in the day I would TOTALLY have bought that tape based on the art and screenshots!
- freshlamb
Physical copy still available at Cronosoft: https://cronosoft.fwscart.com/BLUE_STAR ... 28118.aspx
Just bumping this to see if you still have the source code, Kweepa? It looks like the link is dead. I downloaded it like...15 years ago, but I must have misplaced it.
Also, this is still one of my favorite Vic-20 games, and any newcomers to the community should check it out!
- Kweepa
Yep, it's attached.
Thanks for the kind words!
- BlueStar8Apr2008.zip
- (22.08 KiB) Downloaded 134 times
Awesome!
Thanks, Kweepa!
Thanks, Kweepa!
