Final Expansion :: 512KB SRAM + 512KB EEPROM + SD Card (2GB)
Great!brain wrote:Can I get information on the "case" you're planning? I'm working on a mold for VIC cases, but I'd rather not duplicate effort.
We've got a (limited of course) number of unused old cases. We are NOT working on a mold - so I highly appreciate your work and would be happy if I'd could buy new cases from you some day!
Our old cases need some work, since there's no slot for the SD-card and no holes for the keys. We'd like to offer this with a professionally printed label and all the mechanical works done. Finally, it should look like this:
- Pedro Lambrini
Please excuse the delay... Have been busy with tests and other things.Vic20-Ian wrote:waiting to hear about being a Beta Tester
I'll send the order forms today
The parts listet below are the "Other parts". Thus you can compare prices.
Though you could get them at your local dealer, I highly recommend to take the ones I offer to make sure you'll get the right parts and they'll fit into the cartridge case!
The parts listed below are the essential parts:
Part Value Package
ATF1504 IC4 3M44 Programmed CPLD
CON1 SCDA5A0201 SCDA5A0201 Card-reader (push-in, push-out) by ALPS
IC5 ATMEGA644 DIL40 Controller programmed with boot-loader, fuses set
IC6 LT1117CST-3.3 SOT223 3.3V voltage controller
The parts listet below are the "Other parts":
Qty Part Value Package
7 C1-5, C9-10 100nF C5B2.5 *** must be small caps! ***
2 C6-7 27pF C025-025X050 rcl
1 C8 22µF E2-4 *** tantal caps only! ***
3 D1-3 BAT85 DO34-7 diode
1 IC1 AM29F040N DIL32-6 *** AM29F040B type only! ***
1 IC2 628512 DIL32 SRAM 512KBx8
1 IC3 74LS245N DIL20 *** LS type only! ***
1 IC7 PCF8583P DIL08 I2C real time clock
1 JP1-12 Pin connector 1x40
5 JP1-12 Jumper
1 Q1 8 MHz HC49U-V crystal
1 Q2 32768 kHz TC26H crystal
3 R1-3 3k3 0207/10 Resistor 1/4W
5 R4-6, R8-9 1k8 0207/10 Resistor 1/4W
3 R7, R10-11 10k 0207/10 Resistor 1/4W
2 IC1,IC2 Socket DIL32-6 *** flat type only! ***
1 IC3 Socket DIL20 *** flat type only! ***
1 IC4 Socket PLCC44
1 JP2 MAS 60 DIN IEC plug male, 6 pins
1 JP2 Shielded, high flexible cable for IEC, 3 wires+shld
2 T113A RT Key red Reset CPLD+VIC20, Disk change - (Disk ch. optional)
1 T113A GE Key yellow Reset VIC20 only (optional)
1 T113A GN Key green Disk change + (optional)
- Diddl
- Website: https://oe7twj.at/
- Occupation: software engineer
- Diddl
- Diddl
Zorro visited me today and we found and fixed the error and improved the build instructions to avoid this in future builds.carlsson wrote:I was hoping to see the FE in action last weekend, but the kit Zorro soldered together never did seem to work. He had sourced some chip from another to be able to update the firmware from SD, perhaps that chip was not properly programmed after all.
His SD-Card contained a partition table but the boot loader needs a FAT 16 formatted card without partition table.
Once we used a SD-Card with FAT 16 and no partition table, it flashed itself in seconds and since then, it runs!
Once SD2IEC's firmware is installed, it can handle cards with FAT32 too - FAT16 is only needed to install the firmware.
Hmm, the bootloader that Shadowolf modified and Unseen has on his web site supports partitions, although only the latest code I sent Unseen supports FAT32 filesystems.for(;;) wrote:Zorro visited me today and we found and fixed the error and improved the build instructions to avoid this in future builds.
In any event, I'd recommend using the newer bootloader, as it handles FAT32 and partitions.
Jim
I used bootloader_LarsP_M644.hex from http://sd2iec.de/bootloader/sd2iec_boot ... +LarsP.zipbrain wrote:Hmm, the bootloader that Shadowolf modified and Unseen has on his web site supports partitions, although only the latest code I sent Unseen supports FAT32 filesystems.
Thank you! Good news. I'll ask Unseen for the latest code.brain wrote: In any event, I'd recommend using the newer bootloader, as it handles FAT32 and partitions.
edit 2008-08-07:
Jim Brain sent me the latest bootloader and I testet it both with FAT16/FAT32 and with/without partition table.
It works fine!
I've reprogrammed all the Atmels I already prepared so all FE3 kits beeing shipped from now on will use the new bootloader.
Thanks a lot for the code, Jim!
Beta kit arrived today!
Very well packed, nicely presented and invoiced.
Circuit board looks high quality. Good high quality chip holders (turned pin type)
Looks very high quality overall and appreciate the "Nerve Food Gummi Bears for self builders"
Looking forward to building next few days.
Ian
Ian
