nbla000 wrote:My english is not perfect but i hope you understand me, if you need software help for the flashcart i may help you, if i can and i'm able, but only when i finish the MegaCart Project and this because i'm really busy with real life and because for a lot of reasons i started to work with MegaCart before and normally i use to finish a work to start another, is difficult for me to follow 2 hard project like Mega and flash Carts jointly, i need to work on "real world" too
The point I wanted to get across is that the Flashcart and the Megacart are in fact so close to each other from a software point of view that it would only require me to do 2 or 3 rewirings on the Flashcart to make it perfectly compatible with the Megacart's software.
So, yes, technically, it would be very easy to make a few change to the Flashcart's hardware so that the software from the Megacart runs on it without any alteration whatsoever.
The only ONE thing that is substantially different is the reset system which is triggered on the Flashcart as soon as you choose a new cell for BLK2/5 while it is triggered by a poke to a control register on the Megacart. But even that is not something I could call a major hurdle.
In the past, I remember Brian saying that it was rather presomptuous of me to assume something like I just said. However, for example, if you look at the differences between the 2 prong VIC and the VIC cr, these differences, even if they are quite substantial, do not prevent a complete software compatibility.
AFAIK, there is no software that works well on the older VIC and not on the newer one or vice versa.
So yes, I could simply wait for you guys to complete the work on the Megacart, see if its either possible to modify the hardware to work with the software as is or to modify the software to work on the hardware as is.
And that is up to you guys to decide wether its something that you would like to see or not.
KilrPilr said in the past that the reason why Brian started the Megacart project is because I was doing nothing and going nowhere with the project. In fact, I did show up mith an operational multicart that more or less matched what I first envisioned as a multicart. It did what I first claimed it could do and it turned out to have double the number of games I first anticipated.
The Behr-Bonz cart is not the Megacart and it doesn't pretend to do all the Megacart does but its a project thats a lot dearer to my heart than the Flashcart and it works right here right now.
And if you really want to do a minicart well, there you have it... its there, its done and it works. If you ordered 100 of them today, I could have them for you just before christmas! It sure could benefit from having both PAL and NTSC support which right now it does not have and perhaps a much better looking and sounding menu.
In other words, this project could benefit from your implication. I put in it pretty much everything I could given my availability and my knowledge. I can also assure you that given my personnal philosophy of
anti leet, I will make the plans and the ROM content public.
Are you going to see the opportunity and make positive contributions to it or reject it as worthless? Are you going to allow that the PAL/NTSC fixed games originally intended for the Megacart be used in it or are you going to shove me aside in my little corner?
Now the ball is on your side.
