Introducing VFLI for VIC-20: 208x256 pixels in 16 colours!
I should give credit to the original test image of Roger Atrill's PowerShade (later renamed to Merlin) which had been a raytracer specifically tuned to the Acorn Archimedes platform. Here are some other examples, 'ballrings' is in the top row:orion70 wrote:Geez, this image is just IMPRESSIVE.
http://www.fortunecity.com/meltingpot/c ... allery.htm
I was involved in there forasmuch I had been hired in those days to write an editor, which would emit text files as scene descriptions for this raytracer. Within the GUI, objects in the scene could be edited as wire-frame models. The money I earned from that contract paid off the A5000 I had bought half a year earlier.
That's incredible !Mike wrote: I just tried out the converter with a raytraced example image in the proposed 168x320i mode, here's how the result would look like:
In the meantime I tested Mega-Cart on my modded VIC-20 for compatibility: several cartridge games, utilities (Waterloo BASIC, ...), the tape section, the demos (Robotic Liberation, ...) and the standard BASIC prompt with memory expansion.nbla000 wrote:Mega-Cart: the cartridge you plug in once and for all.
Nearly everything behaved normally, just the menu-point 'RESET > unexpanded VIC' really didn't return me to 3583 BYTES FREE. Rather the internal expansion still was included. It seems Mega-Cart switches itself off in that case and then calls the normal reset routine, which then of course includes the internal expansion. On the contrary, when I started Waterloo BASIC unexpanded, I indeed got the '3.5K free' prompt - presumably all RAM on Mega-Cart is activated (including BLK5), and the BASIC pointers in 642, 644 and 648 are just pre-set as necessary.
I surely didn't mod my VIC-20 for no reason.That's incredible!
Here's the NMI display routine for *.hhm pictures (208x256 "original" MAXIGRAFIK) on a VFLI-equipped VIC-20: (download)
Unlike MAXIGRAFIK, this mode leaves nearly 100% CPU power available to the running program and it also allows for disc access - indeed in the slide show the pictures are loaded while they're being displayed. This is achieved with two NMIs which switch between the charset located at $0400 and located at $1000, in the middle of the screen and somewhere during vertical retrace.
I've included the source for those interested. Besides the VFLI mod (at least the internal expansion to 8K), an external 8K RAM expansion also is required. Tested on my VIC-20 + FE3.
- Omega Star Commander
Sweet!
Sure.rhurst wrote:Sweet!
Pop-quiz: what's the reason behind the following code snippet in the NMI display routine - and what does it do?
TSX
LDA &0105,X
CMP #&F1
BNE Server_00
LDA &0104,X
CMP #&66
BCC Server_00
CMP #&6D
BCS Server_00
LDA #&6D
STA &0104,X
.Server_00
Let me guess:
Ensure that the IER of VIA 1 is set correctly on exit from NMI.
(Slightly) longer explanation:
The return address is reset to $F166 if it is in the area $F166-$F16D.
Thereby, the enclosed operation (conditionally) modifying the IER register is safe from NMI interrupts.
Nice routine!
Nice routine!
Not quite, but close.
This small routine in the kernal ROM is called at two places when the kernal enters a time-critical section: in the LISTEN routine and at the start of tape operation, to ensure no NMIs of the RS232 routines would step unto their feet:
The branch at $F164 is probably never executed, because normally at least the RESTORE key NMI is enabled.
During display however, the RESTORE key *is* disabled and Timer 1 is enabled instead - being the only source of NMIs for now. When the above subroutine is called, the AND instruction at $F169 will determine at least one of the timer NMIs is enabled - and waits ... and waits ... and waits, until both timer NMIs have been disabled.
Which - during display of the new mode - is not going to happen anytime soon.
Now, my code snippet above senses this condition during NMI execution (stacked program counter within the loop?), and deliberately alters the return address on stack to the instruction immediately following the loop. After return from the NMI the two instructions at $F16D and $F16F disable NMIs from CB1 (which doesn't do any harm here) and then the routine exits cleanly.
The next NMI is only due in 10 milliseconds and so is guaranteed not to interfere with the LISTEN routine, which includes a 1 ms busy wait to check for EOI or 'device not present'.
.F160 48 PHA
.F161 AD 1E 91 LDA $911E
.F164 F0 0C BEQ $F172
.F166 AD 1E 91 LDA $911E
.F169 29 60 AND #$60
.F16B D0 F9 BNE $F166
.F16D A9 10 LDA #$10
.F16F 8D 1E 91 STA $911E
.F172 68 PLA
.F173 60 RTS
Hi!
In the meantime I had a PM exchange with wimoos, his VIC-20 includes an internal 3K expansion as in the VFLI mod. He could confirm that the display routine for *.hhm (original MAXIGRAFIK) files also works on his VIC-20. Only his 64HDD had some struggles, so the images still needed to be loaded while in text mode. So, there are still some open issues.
As I wrote above, on an NTSC VIC-20, there should be a 168x320i mode possible. That would however require someone here adventurous enough to mod his VIC-20 beforehand - and then taking the time to assist me in writing the display driver. This is not going to be an easy task, and most probably even needs some intermediate versions, with screen shots taken with a digital camera exchanged, etc.
Likewise, the mod can also be done on a 2-prong VIC-20. Instead of two 6116 chips, six 2114 chips are piggy-backed on the existing ones, and directly selected with UC4. U13 is not present in the 2-prong main board.
A corresponding BASIC extension might be a nice follow-up.
Finally I had the time to add the S-Video mod to my VIC-20. This again was a collaborate afford with a collegue done last evening.
The video output of my VIC-20 was especially bad behaved: 'split' pixels in cross-hatch patterns, and black-white contrast transient pixels between two different colours of near equal luminance. All in all the video output is now much nearer to the converter preview, which itself now just is missing the PAL colour blending.
Greetings, and a Happy Easter,
I really wish this mod was easier to do. As someone with next to know experience with electronics there's no way I'd let myself with this. I certainly wouldn't trust myself to put a soldering iron to a Vic-20. And I don't know anyone that has the experience to perform such a mod either. It's a shame because these pictures are brilliant and it would be awesome to see some software that could take advantage of this and that a reasonable number of people could use.
Regarding the S-video mod: Wow. That's a dramatic improvement.
If you don't mind me asking, why is it that the output of some Vic-20's is worse than others? I'm guessing it has something to do with the way the signals are mixed since the S-video mod fixes it? Is there any way to improve the video signal (without performing the S-video mod) by just changing a capacitor or something like that? Sorry for asking so many questions, but this is one of the biggest mysteries of the Vic-20 to me.
Happy Easter to you too Mike, orion, and all other Denial members.
I posted a short explanation in the S-Video thread.Wilson wrote:[...] why is it that the output of some Vic-20's is worse than others? [...] this is one of the biggest mysteries of the Vic-20 to me.
