Can a0 files be run on a real Vic-20?
- mrr19121970
- Vic 20 Nerd
Re: Can a0 files be run on a real Vic-20?
yes, yould be. I used @k3ys memory expander
Could you use Snapshots instead. I.e. configure vice, attach the cart and save a snapshot, then load that in your menu?
I would love to try these and see if they work for me, so if you can provide a link where I can download them, it'd be greatly appriciated.Aturnwald wrote:Sorry for interrupt, I've got all available Commodore - Atari - HES cartridges on Zip and on 5 1/4 Zoll Disk, with a easy loader, so I use that on a real VIC, with 16 / 32 K, the memory-dumping ( for e.g. BLK/5 or BLK/3 or BLK/1) would be done by the small loader. If you like these 5 disks, give an answer and I send it to you.
Ok, so by doing this all cartridges should be possible to "convert" into disk-format (d64)? And if so, ARE all cartridges already converted into e.g. d64 by someone (I haven't found them)?Aturnwald wrote:PS: By the way, on a real VIC, it is possible to load a game form Disk into the "machine Monitor" and then you are able to reprogram the cartridge. After that save it again on Disk and run it, that's all.
I hope that was helpful.
mrr19121970 wrote:Look here. There are plenty of carts in the .d64 files with a handy loader
Thanks, these images actually worked pretty good for me using it with Vice20x (for xbox)! They autostarted into the menu, then I just selected the game.... and although I was preferably after a solution were the games autostarted without having to select it in a menu, this is the closest so far!
As I said, that's because these games were cracked so they don't try to self modify. You don't need the memory area used by the cart to be "read-only".Snarko wrote:mrr19121970 wrote:Look here. There are plenty of carts in the .d64 files with a handy loader
These are loaded as opposed to attached.
To use these files on a real VIC-20 you'd need a RAM expansion located in the used areas so obviously you can't make this expansion read-only.
Aturnwald
pls can you send me your link?
i want try.
thx.
i want try.
thx.
mrr19121970
Great collection thx!
but not relocated for "normal" vic-3k 8k 16k.
IMHO, that's expecting a community to rebuild cartridge games because you're not using them properly.Ammiraglio72 wrote:Great collection thx!
"normal" cartridge games run in BLK5.
- Aturnwald
- Occupation: painter & decorator
Hi,
here is the link, hopefully it works. I never tried that before.
https://www.dropbox.com/sh/j2q3y20o4v2v ... _LZka?dl=0
it's on my Dropbox, just take the 4 files with the name "Modulgames xxx" that's all.
.....42, what else ???
ok....
Thx anyway.
I will buy a exp memory 32k with dipswitch and block 5.
i know to relocare roms need all heavy work.
But NLBA000 already relocate some cartridege , but his link is death and he not anwer.
thx all
sorry for bad english
Thx anyway.
thx all
Hi Everyone,
maybe too late but as asked I've attached a rar file with old Cart to prg conversions a 2007 work !
- Cart-conversions.rar
- (68.68 KiB) Downloaded 59 times
- necronom
- Occupation: IT Support
That's excellent! I've been working my way through all the Vic-20 games I can play on my real hardware, and it's been bothering me that there are a lot of great games that are only on cart that I can't play from my SD card with only having a 16k expansion. I'll give these a go. Thanks.
[edit] I've just realised that these might still need a 32k expansion, but I'll try them anyway.
I've just tested these prg with VICE VIC+16k and all these games works.
- necronom
Brilliant!
Nice avatar. I was playing Vic-20 Salmon Run a few days ago. I stuck it on YouTube.
This is an old friend of ours showing up here from time to time... Hello nbla000, how's life going on?
no too bad but last year I had health problem and I went on hospital for a few months now seems all ok, thanks.
