Final Expansion :: 512KB SRAM + 512KB EEPROM + SD Card (2GB)
TNT
Post by TNT »
Is VIC-20 Block 0 ($0400 - $0fff) mapped to SRAM Bank 0 in SUPER RAM mode? Documentation says it's enabled but doesn't specify where it's mapped.
edit: Second question - is there a way to get name of current directory or mounted disk image? I'm thinking of scenario where I might want to CD:<-, do something, then CD:back_to_previous_dir.
I've split the following discussion about TNT's Z-code interpreter, and FE3 into an own thread in the Games section.
Diddl
Website: https://oe7twj.at/
Occupation: software engineer
Post by Diddl »
bugfix release r019a :: many thanks to nbla000!
download as usual at http://vc20final.t-winkler.net/zip/
Image for VICE included ...
TBCVIC
Post by TBCVIC »
Anyone bothered to drill holes for the LEDs? I'm not sure where to put them...or if I should just skip them.
Ola Andersson
Diddl
Post by Diddl »
I don't have connected this LED.
In principle you can drill wherever you want the LED, cause you can wire a longer cable.
TBCVIC
Post by TBCVIC »
What's the dirty LED for? It never turns on for me.
Is there a way to blink the LEDs with a poke?
Ola Andersson
for(;;)
Post by for(;;) »
The dirty LED lights on errors. If you try to load a file that does not exist, it should light - if not, something may be wrong with the connection of the LED.
TBCVIC
Post by TBCVIC »
Ah, yes, that works :)
Ola Andersson
amramsey
Post by amramsey »
Noooooooooooooooooo! After patiently waiting for my FE3 to arrive, it finally showed up in the post today.... right after work told me that I was shipping out to Korea for the next two weeks! :cry:
Figured I'd at least open the box and check out the bits and pieces.... and discovered some Haribo Goldbären goodies. :D Cheered me up! Those are some yummy little bears.
Diddl
Post by Diddl »
You go to Korea for two weeks? So you can enjoy to see Korea and enjoy to build your FE3 after 2 weeks.
Wish you nice days in Korea
Lucky you! THIS is on sale only there! Bring home one...
Pedro Lambrini
Post by Pedro Lambrini »
orion70 wrote:Lucky you! THIS is on sale only there! Bring home one...
Ooh, yes! If you fancied posting one my direction too it would be appreciated! ;)
amramsey
Post by amramsey »
Ha ha. I'm not sure I'll be able to fit that into my carry-on! :D
TBCVIC
Post by TBCVIC »
This is how my FE3 looks like, I've put the LEDs at one side:
Ola Andersson
for(;;)
Post by for(;;) »
Very nice!
Maybe I should drill these holes by default the next time I prepare the cases?
