Hi levoman,
I would just like to add a comment to eslapion's excellent explanation of his glitch testing circuit. Which I might like to say is very easy to build and very reliable.
When purchasing your 74LS279 flip flop IC, I suggest you get several different
quality brands from
known suppliers. Such as Mouser or Digikey.
Maybe even you have a local electronic shop that sells these sort of chips.
I got caught out using a particular brand of 74LS279 chip. I wasn't getting the readings I was expecting.
This is due to small manufacturing differences between the brands and even the batches as well as manufacturing plants.
I recommend using Motorola branded chips.
I found 1 batch of Motorola branded 74LS279 chips had a slightly lowered triggering TTL voltage threshold to that of another batch of Motorola branded 74LS279 chips I tested. In fact the LED was coming on intermittently in that particular batch.
The Motorola branded chips were overall the best in terms of having a triggering voltage threshold that would accurately trigger at the desired TTL voltage threshold.
I am sure eslapion can do a better explanation of what is happening here...
I mean to say that the trigger TTL voltage threshold between these two batches was microscopic. However it did greatly impact on my recorded readings.
For me in the end it was a matter of trying out different varieties of 74LS279 chips against a known dodgy PLA (such as the Winbond W27c512 electrically erasable PROM ) in combination with a factory Commodore PLA chip.
Once you have the right 74LS279 chip in you glitch tester you'll have a good bit of kit to test out your PLA's. So easy to use.
I love my tester
By the way I think the eBay seller TheLittleDiode is a Chinese knockoff reseller who trades out of the UK. Having said this, there is nothing wrong with buying knockoffs, just be prepared for the unexpected!
