Tips for Reverse Engineering a Cassette Program
Re: Tips for Reverse Engineering a Cassette Program
I still get a ?LOAD ERROR with this .tap file.
I can load the TAP file correctly with 8K+ RAM.
Weird, is that with a PAL configuration?
[srowe@gilraen boss-chess]$ unzip ~/Downloads/BOSS-8k.zip
Archive: /home/srowe/Downloads/BOSS-8k.zip
inflating: BOSS-8k.TAP
[srowe@gilraen boss-chess]$ xvic -memory 8k -1 BOSS-8k.TAP
I had the same problem.
Used Tap-Clean on the file and that did the trick.
Now loads OK at warp in vice.
Could you attach the cleaned .tap file?
I still get a ?LOAD ERROR, even with this copy.
Why don't you just use winvice instead of the command line vice? If you are a Linux user, WinE will easily run windows executables.
Tap-Clean reports errors after cleaning but it still works.
Using load will produce a 'LOAD ERROR'.
Using 'shift RUN/STOP' works.
Don't ask me why.
Don't ask me why.
Yep drag and drop into the vice window will in fact emulate a shift+run.
If you see "LOAD ERROR" then the KERNAL has detected long/short blocks and/or checksum errors. Whatever is loaded is corrupt in some way. RUN/STOP only "works" because it rams the characters "LOAD<CR>" "RUN<CR>" into the keyboard buffer, it doesn't magically fix anything.
No, no magic...
...and yet it works.
Yes, it seems that works even if there is a "?LOAD ERROR" but maybe will be problems in a certain condition of the game or something else who knows.
Btw I've tried to create a prg file from both original/cleaned tape but each time it will produce a prg (from $1201 to $3FFF) with different CRC32, it works but I don't trust it.
By filling memory from 1201 to 3fff with an arbitrary value before to load the TAP, you see these value inside this range 1201/3ff and not always in the same place, for me a new dump is better.
there is no such thing as a "command line vice". winvice can be started using the exact same commandline.Why don't you just use winvice instead of the command line vice?
Ok, i meant "launch the program dragging it into the window".
