Bitmap screen and Omega Race
Re: Bitmap screen and Omega Race
hello, good day.
there is an error in the trse.
what can you do for it?
greeting
greeting
tis is one plot in basic:
10200 rem plot
10230 gosub 10400
10240 poke ad,peek(ad) or ma
10250 return
10400 ad=4352
10410 ay=int(y/16)*336+(y and 15)
10420 ad=ad+16*int(x/8)+ay
10430 ma=2^(7-(x and 7))
10440 return
10200 rem plot
10230 gosub 10400
10250 return
10400 ad=4352
10440 return
- AndyH
- Occupation: Developer
That vforth looks interesting.
You might not have the latest version '<<' was added recently, so it is possible it is that. If you a adventurous, the very, very latest is on GitHub.
- AndyH
The new commands (that will be available in the new year) adds some useful methods. If you wanted to plot that wave you could use
vbmSetDisplayMode();
vbmClear(0);
vbmDrawDot(x,y);
please show me the newest version running under window, ihne i have to make a new trse.
greeting
greeting
hello thanks.
is ok with trse.
I'm glad that now also the vic20 is considered in the future.
greeting
is ok with trse.
greeting
if that can be implemented on the fast on plot in trse, that would be fine.
10200 rem plot
10230 gosub 10400
10250 return
10400 ad=4352
10440 return
and :
RightBitShift/LeftBitShift .. expand 16 bits then you can work in the graphics mode at vic20 synonymous.
greeting
10200 rem plot
10230 gosub 10400
10250 return
10400 ad=4352
10440 return
and :
greeting
I compiled this program with target: 8191 and could start it with sys8192.
this not funktion (grafik vic20)
poke(^36867,0,151);
poke(^36866,0,21);
poke(^36869,0,204);
poke(^36864,0,14);
this is the start in the asm : -
ORG $01
schiebechar
jmp block41
charset dc.b $018, $018, $03c, $07e, $0ff, $018, $024, $042
dc.b $0ff, $081, $081, $081, $081, $081, $081, $0ff
thanks
greeting
poke(^36867,0,151);
poke(^36866,0,21);
poke(^36869,0,204);
poke(^36864,0,14);
ORG $01
schiebechar
jmp block41
thanks
greeting
program schiebechar;
var
charset : array[16] of byte = ( 24,24,60,126,255,24,36,66,255,129,129,129,129,129,129,255 );
a, b : byte;
zpcharz: pointer;
zpscr: pointer;
zpcol: pointer;
begin
ClearScreen(white, screen_col_loc);
zpcharz:=5120;
zpscr:=4096;
zpcol:=37888;
poke(^37139,0,0);
poke(^37154,0,127);
poke(^36869,0,205);
poke(^36867,0,151);
for b:=0 to 16 do
begin
zpcharz[b]:=charset[b];
end;
a:=5;
zpscr[0]:=0;
zpcol[0]:=5;
end.
- AndyH
Ctrl + R will start the program in vice and there is a basic stub that will do the sys call for you, unless you turn that off in the project settings.
Also, after definescreen() you will have access to a built in zero page pointer called ScreenMemory which you can use to manipulate the screen (or colour) memory to save allocating an additional zero page pointer.
Not sure how you got org $01 in the ASM? If you can upload the project I can take a closer look.
hello thanks.
$1FFF start ist ok .
8191 not.
then sys8192 ok ;
greeting
8191 not.
then sys8192 ok ;
greeting
what is that.
please explain that to me once:
Thank you.
greeting
Thank you.
greeting
- AndyH
tryfunkheld wrote: ↑Tue Nov 26, 2019 11:41 am what is that.
Thank you.
greeting
definescreen(); // initialises a free ZP pointer called screenmemory - many methods use it
screenmemory := $1000; // you can use it also!
screenmemory[0] := 1;
hello thanks.
greeting.
greeting.
another question.
I want to copy code to a disk and I'm loading memory into the program again.
how does that go with trse please?
Thank you.
greeting
Thank you.
greeting
