French Magazine - Type-Ins - Hebdogiciel
- Vic 20 Devotee
Re: Hebdogiciel
Hey this is Great !
If you need more type-ins :
There are maaany listings on archive.org, too.
In Example : The issues of EMAP - Computer & Video Games
Found already about 25 VIC-Games in the first 35 issues, that need to be typed in.
Issues : 001, 002, 006, 007, 010, 011, 012, 013, 014, 016, 018, 019, 020, 022, 023, 024, 025, 026, 027, 028, 030, 031, 032, 033, Yearbook 84, and so on
(i've already put the *.pdf's in my Gamebase-projekt to "need to be typed in")
eCC-Imagepack-Designer
Done: Vic20, N64, Philips VG-5000-G7000-G7400, SordM5, Amstrad GX4000
Progress: Atari 8bit, Enterprise 64/128, Dosbox
- Kweepa
- Occupation: Game maker
Re: Hebdogiciel
Oh no, not more!!!
- Vic 20 Devotee
Re: Hebdogiciel
@Kweepa: This Listings already exist in TOSEC : EDIT:ok that was clear.... )Kweepa wrote:AP - which one, so I can avoid it? Please post it here too when you're done.
I'm going to type in Flechego from #3 next.
Attack (1985-06-28)(Hebdogiciel)(FR)[issue #89][type-in]
Bolide Circus (1984-05-25)(Hebdogiciel)(FR)[issue #33][type-in]
Cavalier (1984-06-29)(Hebdogiciel)(FR)[issue #38][type-in]
Conjugaisons (1983-10-14)(Hebdogiciel)(FR)[issue #01][type-in][3k]
Fantomergie (1984-02-24)(Hebdogiciel)(FR)[issue #20][type-in]
Jack Pot (1984-12-21)(Hebdogiciel)(FR)[issue #62][type-in]
Tremplin (1984-03-23)(Hebdogiciel)(FR)[issue #24][type-in]
btw.
I will put your type-ins into the TOSEC-Set :
Example :
Golf (1983-10-21)(Hebdogiciel)(FR)[issue #02][type-in].prg
Golf (1983-10-21)(Hebdogiciel)(FR)(en)[tr en Kweepa][issue #02][type-in].prg
- AntiPontifex
- High Performance Typist
Re: Hebdogiciel
@vicman
Thank you for the postings; also, thank you for your vic-20 TOSEC efforts over the years
@joshuadenmark
Sorry for not acknowledging your posting; the greetings are appreciated!
@kweepa
Another one! Thank you! I'm still chipping away but this one is just massive.
@joshuadenmark
@kweepa
- Vic 20 Devotee
Re: Hebdogiciel
Short note for the Game LEM ,Hebdogiciel No 27 du 13 avril 1984 :
This is available only as *.vsf file (vice snapshot image) and not as *.prg or *.d64
Also this *.vsf works only (more or less) in Vice v1.22.....not in vice v2.2 or v2.4
So, this dump need to be fixed, or re-typed as *.prg to run correctly
- LEM_HEBDOGICIEL.zip
- (2.33 KiB) Downloaded 82 times
- Kweepa
Re: Hebdogiciel
#6 AUTO-CROSS
http://www.kweepa.com/step/vic20/games/heb6auto.prg
English translation:
http://www.kweepa.com/step/vic20/games/heb6auto-en.prg
A game with very simple mechanics, but quite fun because of the time limit. It would probably be slightly more playable with steering controls and continuous motion, like 'Snake'.
There's a POKE900,0 that appears to do nothing in the listing (since that's the middle of the cassette buffer)...
- Kweepa
Re: Hebdogiciel
#7 PERDS PAS LA BALLE
http://www.kweepa.com/step/vic20/games/heb7perd.txt
http://www.kweepa.com/step/vic20/games/heb7perd.prg
http://www.kweepa.com/step/vic20/games/heb7perd-en.txt
http://www.kweepa.com/step/vic20/games/heb7perd-en.prg
An extremely frustrating pachinko style game (I scored 0 several times) with a seizure-inducing title page. The code is very tidy
It has three different names (Bille, Perds pas la Bille, and Perds pas la Balle) so I chose the headline title in the magazine.
- Kweepa
Re: Hebdogiciel
#8 DIX PETITS HUMAINS
http://www.kweepa.com/step/vic20/games/heb8dixp.txt
http://www.kweepa.com/step/vic20/games/heb8dixp.prg
http://www.kweepa.com/step/vic20/games/heb8dixp-en.txt
http://www.kweepa.com/step/vic20/games/heb8dixp-en.prg
A Snake game where the snake behaves more like a light cycle. Requires making a plan before starting to move!
The game was originally called Boa Croqueur (Boa Muncher).
There's a key peeker at the bottom of the program, which I used to deduce the keys - W A D Z.
- Vic 20 Devotee
Re: Hebdogiciel
Thank You Kweepa ,
but please re-upload the english *.txt file for Perds Pas La Bille.
The uploaded txt is very "crypted"....
⪏⨪⨪⨪⨪⨪⨪⨪⨪⨪⨪*္⪏娪剅佈乕⁉䅋䥒⩍⨪⨪*ၕ⪏⨪⨪⨪⨪ ခဝ
btw.
I got 40 points in my first try
btw.
- Kweepa
Re: Hebdogiciel
#9 TIR AUX PIGEONS
http://www.kweepa.com/step/vic20/games/heb9tirs.txt
http://www.kweepa.com/step/vic20/games/heb9tirs.prg
http://www.kweepa.com/step/vic20/games/heb9tirs-en.txt
http://www.kweepa.com/step/vic20/games/heb9tirs-en.prg
Quite a challenging game - like Asteroids with only one asteroid.
- Kweepa
Re: Hebdogiciel
@vicman - updated the text file for Perds pas la Bille (en). Thanks for noticing!
- Vic 20 Devotee
Re: Hebdogiciel
just a note to the Game #7 PERDS PAS LA BILLE (BALLE) :
It seems there is something wrong with the code (program-listing).
If i loose the Game, and i choose Yes for play again, then :
a) the screen jumps / moves one line down
b) the "new" game never ends (it doesn't matter how many balls I'll let by)
EDIT:
btw.
An Admin should rename this Topic into "French Magazine - Type-Ins - Hebdogiciel"
as tokra has made it with his German Magaznes
EDIT:
btw.
- Kweepa
Re: French Magazine - Type-Ins - Hebdogiciel
#10 GEOFRANCE
http://www.kweepa.com/step/vic20/games/heb10geo.prg
http://www.kweepa.com/step/vic20/games/heb10geo.txt
A French geography quiz that's going to be pretty tricky for those not of the garlic-eating persuasion.
- Kweepa
Re: Hebdogiciel
Ah, you have to type YES or NO, not Y or N. Otherwise it falls into the new score routine underneath. That was in the original code... part of the charm of the type-in?Vicman *1970 wrote:just a note to the Game #7 PERDS PAS LA BILLE (BALLE) :
- Vic 20 Devotee
That's it , thanks.
