Have never heard of Fedora but binaries can be found here:
http://sourceforge.net/projects/vice-em ... /binaries/
VICE 2.3 released
- e5frog
- Vic 20 Nerd
- Website: http://channelf.se
Excellent new release . I particularly like the CRT emulation, and the true aspect ratio adjustment. Minor flaw: the vpl external palette I was using is not working anymore. I guess it's because of different gamma correction, as stated in the docs.
- e5frog
- Vic 20 Nerd
Isn't the "CRT emulation" the same as the mode called "PAL emulation" in the previous version?
I had to clear away the vice.ini to make the picture gamma appear right and to be able to save it, have you tried that to make that vpl palette work?
I tried, but it won't work, even installing VICE in a computer where previous versions were never installed. The vpl palette is reported below:
Hints?
# VICE Palette file
# Syntax:
# Red Green Blue Dither
# Black
00 00 00 0
# White
FF FF FF E
# Red
B4 18 18 4
# Cyan
4C E6 D8 C
# Purple
BC 29 CA 8
# Green
42 E4 36 4
# Blue
32 2A C8 4
# Yellow
D2 E1 26 C
# Orange
CA 5A 02 4
# Light Orange
DE AC 80 4
# Pink
DC 94 94 8
# Light Cyan
A5 F4 EC 4
# Light Purple
E0 9A E4 8
# Light Green
A0 F2 9A 8
# Light Blue
9C 92 E4 8
# Light Yellow
EF F8 9A C
I solved this problem:
1) The new vpl file format has blank lines between colours, and it won't work if written the old way. A VICE 2.3 version of the vpl file for "true" VIC colours can be downloaded HERE.
2) Nevertheless, choosing this palette from the VICE menu (SETTINGS > VIDEO SETTINGS > VIC PALETTE > check External Palette and browse for file) will give an error message. You have to edit VICE.INI instead, as follows:
...and restart VICE. Of course, you will put 6161-101-2.vpl in the VIC20 dir of VICE. Et voilà!
[VIC20]
VICVideoCache=1
VICDoubleScan=0
HwScalePossible=0
VICScale2x=0
VICDoubleSize=1
VICPaletteFile="6561-101-2.vpl"
VICExternalPalette=1
- e5frog
- Vic 20 Nerd
It really sucks when they change something that trivial and render all old files useless.
