Mega-Cart Tools V1.0 released (with dumper + full source)
What were you searching for? The words "Mega-Cart" and "dumper" appear in both the subject and multiple posts so regardless of whether you searched for posts or topics, this should have been the first result. Please let me know what you were searching for I can figure out if something is broken. Thanks.Vic20-Ian wrote:Just adding a quicl post to make this thread more searchable - took me 20 mins to find it.
Hi,
Well i tried to dump but.....
Its failed every time
L:14:0c00
Failed !
Have i done something wrong maybe ?
Using 1541U on device 9
Regards
Sjakie43
L:14:0c00
Failed !
Regards
Sjakie43
Demobase Vic20,C64,Plus4,Amiga and more..
Gamebase Vic20V01
VIC20+Megacart+ Tapuino tape loader
Ultimate 64 in transparant case+blue led
The C64 and The VIC20
https://archive.org/details/DemobaseVic20
Gamebase Vic20V01
I'm just gonna guess here, but, did you put the "mega-extract.prg" into a d64 and then mount the d64?sjakie43 wrote:Hi,
L:14:0c00
Failed !
Regards
Sjakie43
If I'm right then your d64 is getting full before the dumping process has finished.
Try putting "mega-extract.prg" into a folder on your SD card then load/run it from there.
Ray..
I have made a new dir and put the loose megaextract prg in that dir.
But i can only load or run the file, when i do that the c64 tries to load it.
I tried to connect the 1541U in standalone to the vic20 but then i cannot access the 1541U as far as i know.
And i checked the d64 i used earlier, indeed it tries to save the rom to the d64.
I have also tried to remove the d64 after mounting and loading it on the vic,,,,but then the dumping fails immediately.
I have also tried mounting and loading the d64 with dev 8 and after that changing it to device 9 on the 1541U, still no difference.
Btw, the dumping only starts when i exit the 1541U main menu.
Sjakie43
Sjakie43
Gamebase Vic20V01
Gamebase Vic20V01
- Omega Star Commander
That's odd., but I've seen this behavior myself I had issues with what was described as "tolerances" with a 2nd drive attached. I finally used a solo 1581 drive to do the dump in chunks. I've been meaning to dump the latest revision I have in my 2nd Mega-Cart, just haven't touched any real C= hardware in 2-years!
If you need a copy, my first dump of an earlier version can be found here: http://robert.hurst-ri.us/downloads/
My odd vic-20 ....lol
Thanx for the link Robert but i cannot seem to download it, opens a page full of tekst,, maybe my browser(explorer) is at fault ?
Regards
Sjakie43
Now go and play with the VIC !
Regards
Sjakie43
Gamebase Vic20V01
Gamebase Vic20V01
I grabbed it with firefox instead.....
I will check it out , thnx Robert
Regards
Sjakie43
Regards
Sjakie43
Gamebase Vic20V01
Gamebase Vic20V01
