English Invader wrote:If it's possible to build a new cartridge for the VIC, would it be possible to build a 1530 datasette or a 1540/1541 disk drive? Maybe even the VIC-20 itself? Certainly, it must be possible to build individual parts for the VIC and its peripherals.
Then Golan said:
gklinger wrote:Reproducing the boards isn't all that difficult but sourcing the chips, some of which are no longer made, could prove difficult. It's certainly doable though.
AFAIK, all electronic components that are on both the older 2 prong VIC and the newer rev. C (called VIC Cr by some) boards are still available and in production except for the 6560/6561 video chips.
The SRAM chips may not be in production anymore but the 2k x 8 and 1k x 4 sram chips used in VICs are still easily obtainable from Jameco and other distributors.
The 6502 and 6522 chips are still made using modern CMOS technology by the western design center.
In the datasette and 1541, ALL electronic components or equivalent are still available. The culprit there is truly the mechanical components and special RW heads. Altough in the case of the datasette, a standard portable cassette recorder's RW head and mechanism may do the job just fine.
