I just ordered a uIEC/SD
M2I has no advantages over direct storage, especially if you use P00 files to preserve the PETSCII file name. It's the number one entry on the list of features that will be dropped if space gets tight.carlsson wrote:By the way, what would be the difference between storing PRG files on their own in various folders or making M2I images, assuming the total space per folder is more that what a D64 image can hold?
True, the SD card has some FAT format and whichever limitations in file names it implies while I suppose both D64 and M2I would rather contain PETSCII file names. Program files stored directly would be easier to manipulate on a PC, while I suppose e.g. SEQ files need to be put inside an image?
![Image](http://www.cbm.sfks.se/i/compact.gif)
![Image](http://www.cbm.sfks.se/i/vic20.gif)
![Image](http://www.cbm.sfks.se/i/c64.gif)
![Image](http://www.cbm.sfks.se/i/electron.gif)
![Image](http://www.cbm.sfks.se/i/bbc-b.gif)
- Schema
- factor
Another reason why you should use JiffyDOS or EasyLoad. Directories are displayed as they are read and not stored in memory, so you can have huge directories.Jeff-20 wrote:I assume I need separate folders, right? The directory would need to fit into the 3.5k of memory
In fact, my GAMES\UNEXPANDED directory has several hundred games, so to narrow it down a bit I use a wildcard (JiffyDOS, going from memory here):
@$Z* would list all programs starting with Z.
The 1581 has a limit of 296 files which can probably be exceeded if you use subpartitions to get additional directories. I assume that the higher-capacity IEEE drives also allow for more than 144 files because they have more sectors available on the directory track.gklinger wrote:Just as an FYI, you can have no more than 144 individual files on a Commodore formatted floppy, single or double sided.
- Pedro Lambrini
Ah, so it's not device 8 out of the box then? I got a DEVICE NOT PRESENT error. So, I'll change it to device 8 as I don't have a disk drive attached at the minute.
I remember reading a review of the device somewhere containing loads of tit-bits but I just can't remember where about....![Smile :)](./images/smilies/icon_smile.gif)
Mantra:Pedro Lambrini wrote:So, I'll change it to device 8 as I don't have a disk drive attached at the minute.
OPEN 15,10,15,"U0>"+CHR$(8):CLOSE15
To make that change permanent send "XW" to the new device number (8 in the above example). Or you could just address it as device 10.
You're probably thinking of the review written by Larry from Port Commodore but his website appears to be in transition and the review isn't currently available (it was here).I remember reading a review of the device somewhere containing loads of tit-bits but I just can't remember where about.... :)
- Pedro Lambrini
Great. it'll be nearly impossible for me to get and install JiffyDos.
So, it seems I will have some limits on the number of files I can store regardless of SD card size. Even with, let's say, 110 files per folder, I'd only be able to store 110 folders in memory when I load to my 3.5k.
Not that 12,100 is not enough! I can switch off files from my hard drive to avoid keeping memory expansion connected.
(I like to start my VIC with a modest 3581 bytes free, thank you very much)
![Sad :(](./images/smilies/icon_sad.gif)
Oh.. I believe the SD card can be split into multiple partitions, which would give you room for 12100 files per partition.
The ~110 folders also assume you would lay out all files in a flat structure. If you create a deeper structure, you can have as many folders as the memory card capacity will allow:
Well, you understand. On the other hand all the files you store should be executable on unexpanded VIC-20 and while there exists a lot of software, I'm unsure if you can have over 12000 unique titles.
GAMES
|___ SPACE
|___ A-C
|___ D-K
|___ L-S
|___ T-Z
|___ SPORTS
|___ PUZZLES
|___ A-H
|___ J-Q
|___ S-Z
|___ PLATFORM
|___ MAZE
TOOLS
|___ GRAPHICS
|___ SOUND
|___ BASIC
|___ MONITORS
DEMOS
|___ OLD
|___ PWP
|___ PU-239
|___ OTHERS
Although that is possible and uIEC has no problems with partitioned cards, my recommendation is to avoid partitioning SD cards. Windows (at least XP) won't let you access anything but the first partition.carlsson wrote:Oh.. I believe the SD card can be split into multiple partitions, which would give you room for 12100 files per partition.
Yes, with EasyLoad+ you can type @"CD:DIRECTORY" or @"CD:IMAGE.D64" to change directory.carlsson wrote:Jeff: There is a special DOS command sent to the uIEC device called CD:
OPEN1,10,15,"CD:DIRECTORY":CLOSE1
OPEN1,10,15,"CD:IMAGE.D64":CLOSE1
If you have a DOS wedge you can just type @"CD:DIRECTORY", in quotes due to not mixing it with the @C file copy command.
