My new tiny site
nbla000 wrote:Why not TAP files too?
Because I don't know how to convert t64 to tap :oops:
Tried with wav-prg but it extracts single wavs from every entry of the t64 file. I have to extract every single prog into a wav, merge wavs together with a sound editor, and finally convert the (huge!) final wav into a tap. There should be a faster way to do it, yet I can't find it... 8)
Someone please illuminate me!
nbla000
Salmon Run
Post by nbla000 »
orion70 wrote: Because I don't know how to convert t64 to tap
use wavprg-3.3-win32 (wavprg.exe)
select second option "Convert a PRG, P00 or T64 file to a sound or TAP or WAV" and OK
Output format "Kernel loader" C64/VIC20/PET and OK
select the T64 file and one program and after the output TAP file
ok now you have x tap files, to join them in a dos box simple type:
COPY /B FILE1.TAP + FILE2.TAP + FILE3.TAP FINAL.TAP
where FINAL.TAP is the joined TAP file.
nbla000 wrote:Good work!!!!
Thanks nbla000 - I converted all the t64s to tap files (separate tap files for each cassette side):
http://it.geocities.com/orion010870/pot_tap.zip
Enjoy. :)
BTW: anyone heard of someone having paper mags of issues #3-4-5? Simple photocopies would be great for my purpose (prepare a pdf of all issues).
