1541 drive spinning on power up and still spinning
Nathan
Post by Nathan »
How to fix this? I got a C64 with the drive and I tested the drive it works but it keeps on spinning after power up
Commodore 128D < mine
Vic 20 < mine
12 floppy disks worth of games
C2N datasette
C64 < mine now haha!
One does not throw out his old stuff! - me
Nathan
Post by Nathan »
And also the red light keeps flashing too
Vic 20 < mine
C2N datasette
Post by Vic20-Ian »
try
load"$",8,1
List
load"progname",8
run
If it reads a directory and the light does not flash then it should be fine.
Light flash is usually an error in command entry or load errror
N.B. Assumes the drive switches are set to device 8
If you get no response try ,9 ,10 ,11 instead.
Nathan
Post by Nathan »
thanks i will try that
Vic 20 < mine
C2N datasette
callan
Post by callan »
If it's spinning constantly, AND the drive active LED is flashing - then it's failing its power on self test.
USUALLY that means that the RAM chip, or one of the ROM chips has failed.
How many flashes in each sequence ?
Callan
Nathan
Post by Nathan »
It didn't do anything and its still doing the same thing, so do I need a new drive?
Vic 20 < mine
C2N datasette
PaulQ
undead vic
Post by PaulQ »
I agree with Callan. If this were my disk drive, I'd get one that passes its test but can't read any disks for cheap (or free), and swap the board in.
Might just be a bad VIA 6522 chip. These are cheap and easy to replace. There is an article which tells you exactly what each set of symptoms mean floating around on the internet from Ray Carlsen (sp?).
Nathan
Post by Nathan »
Could you get me a link? I need to replace the VIA now >.>
Vic 20 < mine
C2N datasette
Nathan wrote:Could you get me a link? I need to replace the VIA now >.>
Have you tried Googling "Ray Carlsen" and "1541"? I'm sure you will find it. His Commodore repair articles are all over the internet.
